U
ukpablo
ok
have been asked to fit a wireless stat.
old set up, traditional boiler going to digital timer unit, feeding an old dial type thermostat. Customer wants that removing and replacing with a honeywell wireless stat. so do i remove the old digital timer unit as the wireless stat is programmable???
or do i just wire the wireless stat where the old one was?
have not done any of these before, i did download all files previously posted on here regarding wiring diagrams, however it all is still not clear?????
any pointers would be appreciated.:confused:
If it is a programmable stat then no need for seperate digital time clock. So ideally if you could use the position of the timer to fit the wireless receiver then that should be job done.
wireless stat
Thread Tags
ukpablo,
ukpablo,
