Wireless switches (Lights) | on ElectriciansForums
Discuss Wireless switches (Lights) in the Australia area at ElectriciansForums.net
SKY
Got a customer who after a very expensive extension has realised that he has got the switching wrong after all the rooms have been decorated.
Is there such thing as wireless system were the unit can site above the ceiling in the loft and be switched by a wall mount remote switch?
I assume that its something along the lines of: multiway switching was expected but has been left with a single way switch.?
If you have access to the feed for the light/lights in the extension then you might short out the manual switch, or disconnect at the 3-plate, and use any one of a number of wireless systems with wall mounted and fob activated switches.
You might try Wisebox
Reply to Wireless switches (Lights) in the Australia area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
