Wireless tank stat with temperature readout | on ElectriciansForums
Discuss Wireless tank stat with temperature readout in the Central Heating Systems area at ElectriciansForums.net
Highlands
I am having trouble finding a wireless tank thermostat that gives a remote readout and adjustment.
Does anyone know of a company that makes these?
There's lots available, what's the application? Do you need GSM, bluetooth, TCP/IP, does it need to be ipaddressable? Is it just giving an on/off signal or is it required to modulate another component gradually according to temperature? Do you need to be able to set perameterssuch as set temperatures and differentials remotely? Do you require PID functionality?
Thanks for the replies.
I am currently using a simple mechanical tank stat for hot water control. I need to have a remote setting for the temperature, either wired or wireless plus a readout of the actual temperature and target temperature, simple on/off control. The wireless range would be no more than 20m so 430Mhz band sufficient.
I should add I only require a stand alone thermostat sensor with remote readout/control with a simple C/O relay to interface into the heating control scheme.
Reply to Wireless tank stat with temperature readout in the Central Heating Systems area at ElectriciansForums.net
L
Underground oil tank feed problem This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not...
LostinFrance
L
M
Tree roots near oil tanks I have a large oil tank spaced 1m from the garden fence. It sits on a concrete slab that extends about 0.5m from the...
M
