wireless timeclock, salus. | on ElectriciansForums
Discuss wireless timeclock, salus. in the Central Heating Systems area at ElectriciansForums.net
L
linfieldfc
A plumber has asked me to install this new wireless timeclock which is controlled by a wireless controller which connects to the wifi hub and this controller can also be controlled by an iPhone. Im just wondering has anyone installed this before itd a Salus product if that helps. P.s, it seems to me that its just a matter of replacing the timeclock and setting up the controller etc, as no stats have to be changed, is it as easy as that?
Wrong.
There's only one ch zone and hot water, anyone care to enlighten me as this piece of kit is new to me. Thanks. I think you only need to use the wireless stat if its controlling 2 ch zones. Am I right? All help appreciated.
The Salus IT 500 controller replaces both the central heating controller AND room stat.
Reply to wireless timeclock, salus. in the Central Heating Systems area at ElectriciansForums.net
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
