uksparks
Hi,
I am just trying to get my head around this and wondered if anyone would be able to advise me as I am not 100% I have it correct.
basically I am trying to wire 2x PIR sensors (as per link below) to a couple of security lights.
This is the sensor: http://www.free-instruction-manuals.com/pdf/p3421029.pdf
At each sensor you have
Live
Neutral
Earth
Switched Live
with one sensor you connect the supply to the Live, Neutral and Earth and then connect the light to the Switched Live, neutral and earth.
What i don't seem to be able to get my head around is how to connect both of them together?
Do I connect live neutral and earth on both of them in parallel so live to live, neutral to neutral and earth to earth?
but then the switched live, I don't really know what to do with it? Does that just connect in the same way, then just connect the light off one of the PIRs?
Thanks.
Live
Neutral
Earth
Switched Live
Thanks.
