Wiring a 240v motor to a push button on/off switch? | on ElectriciansForums
Discuss Wiring a 240v motor to a push button on/off switch? in the DIY Electrical Advice area at ElectriciansForums.net
Harddisk25
Boston, Lincolnshire
Hi, I've got a 1950's motor that i would like to wire to a push button on/off switch.
Is the a push button switch on the market to do what i want in the diagram or a way of wiring one as i can not find any on ebay? The only ones i can find that is a close match is the 3 phase switches like this one (ebay No. 290930766073).
[ElectriciansForums.net] Wiring a 240v motor to a push button on/off switch?
What type of motor is it? What size motor? Why not just use a DOL starter and you're protecting the motor as well that way?
Yeah, 1/4 HP is very small, the DOL starter would probably cost double what the motor costs.
How are you going to mount the switch? You just need a 5 Amp, 230v 2-pole switch. You can use a single button latching switch, press once for on and press again for off.
ffs ???????????????/
What is the motor doing would it pose a risk if power failed and was re-established causing the motor to start without warning?... if so then you will need a device that will drop out with power loss and stop the motor starting up again on power up without a deliberate action.
Edit ... your last response just answered half my query...but i was writing when you posted.
its relatively easy you can just use an on off switch or you can use a non latching switches with a relay so as your picture what you need is two two way push switches with normally open and normally closed contacts and a relay its not easy to explain how to do it let me have your email and ill do you a diagram should be able to do it for less than ÂŁ10
So you'll need a switch with it's own enclosure at the back to contain the connections. Have a look at your local electronics shop or Maplins maybe for a small project box and a 2-pole 230v 5 Amp switch that will mount in it. You'll also need a couple of 20mm glands for the cable entries.
[ElectriciansForums.net] Wiring a 240v motor to a push button on/off switch?Little drawing of circuit for it parts you can get from ebay CPC or maplin
  • [ElectriciansForums.net] Wiring a 240v motor to a push button on/off switch?
The other problem with that arrangement is that the start pushbutton will have to make the motor inrush current instead of just the relay coil current and if it is immediately released before the relay has latched, break it as well. Separate contacts should be used for the motor and holding circuit.
But for a compressor I can't see why you would need no-volt release, after all when the pressure switch closes the motor will start by itself anyway. Talking of which, where is the pressure switch?
Your right dark wood my error what happens when you do it in a rush
Sorry incorrect motor is not connected to the switch the supply for that comes through the relay , pressure switch ??? its just an on off switch, the pressure switch would be built into the compressor , no volt release , with this type of switch you have to have a release or youll never switch it off unless you turn the power off , its like any DOL starter once the relay or contactor is energized the power on the out going of the relay is the fed back through the stop switch and overload so if either is operated it switches off the relay or contactor
Reply to Wiring a 240v motor to a push button on/off switch? in the DIY Electrical Advice area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
