Wiring a fan | on ElectriciansForums
Discuss Wiring a fan in the UK Electrical Forum area at ElectriciansForums.net
smity
In this flat it is wired so as it's looped in at the switch and the bathroom light is fed from a switch outside the door is it acceptable to take a 3core from the switch as obviously no permanent live at light?cheers
Reply to Wiring a fan in the UK Electrical Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
