Wiring a Hive Heating Dual Channel Receiver SLR2C | on ElectriciansForums
Discuss Wiring a Hive Heating Dual Channel Receiver SLR2C in the Central Heating Systems area at ElectriciansForums.net
TheConduitKing
Trainee
Northern Ireland
Hey everyone, hope you all had a good xmas.
Got called around to change over an old style pin type thermostat to a hive one for a family member. (Curse the holidays lol) and was a bit confused when I took the old one off the wall and saw how it was wired. I said just to get a central heating guy round to do it, as I don't have much experience doing heating systems.
I'm posting this to hopefully learn how it is wired just for the future.
Timeclock - https://ibb.co/album/SXyBF7
There is a link to see how the old one is wired.
The current heating is an Oil Boiler and when it's switched on it does the hot tank and heats the rads.
What threw me is the orange link cable between the red and the blue which goes out on the black cable. I'm guessing it can't be linking out Line and Neutral, as that wouldn't work and that the black is actually a SW or is doing something. But surely the timeclock needs a neutral of some kind. I've tried doing some research but can't find anything online.
Also that hive is a dual channel and this system would need a single channel? Would I be correct in saying that?
Edit: Also, normally I would have a go and try to figure things out. But I really didn't want to leave them without heating in this weather ovbs. :p
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange' wire just connects the permanent live to both the common contact of the switch and to the clock motor. The black wire is neutral.
The terminals are:
Switched live out (to room stat), Permanent live, Permanent live, Neutral.
This is just a single channel timer. The field wiring looks like 2.5mm2. Are you sure this isn't controlling an immersion element?
Reply to Wiring a Hive Heating Dual Channel Receiver SLR2C in the Central Heating Systems area at ElectriciansForums.net
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
