Can anybody please explain to me, can You have two PIR exterior lights operating from the same master switch?
Each lantern light has its own integrated PIR, each light is positioned either side of a wide garage, which can be approached either from the front or the side. Two PIRs. Each unit has a four terminal conector * L N and the earth. How its wired...... Live feed 1.5 T+E too lamp one via master switch. connected to L N and earth..... 1.5 T+E from * N and earth to lamp two (slave) connected to
* N and earth When flicking the switch 2/3 times, both lights come on for a minute or two, flash three times and go into PIR mode. But they don't seem to be operating at night. Its for a friend of mine. He rang me last night to say there not coming on. Have I wired them correctly?
If there was only one light operated by the switch you would wire the SL to * from the L.
