Wiring a push to break switch | on ElectriciansForums
Discuss Wiring a push to break switch in the UK Electrical Forum area at ElectriciansForums.net
Bognor Regis
Hi.
I have a cupboard light with a one way switch.
I want to put in a 2 amp push to break switch.
Can someone explain the wiring please.
Thanks.
[ElectriciansForums.net] Wiring a push to break switch
Hi.
Thanks.
It’s simple 2 wires
When the actuator is out, the switch is on..
Put a live supply on one side of the switch and switch wire to light on the other side. Join neutrals and cpcs in suitable connectors enclosed inside a box if applicable.
If it is rated 2 amps is it safe to just put the 6 amp cables in
It’s simple 2 wires
So it doesn't matter that a 6 amp cable is going straight into a 2 amp unit?
You have to determine the load the switch will be breaking.
Divide the combined Wattage of the lights the switch will be controlling by 230V to determine the load in Amps.
One 60W lamp divided by 230V = a little over a quarter of an Amp 0.26A.
Reply to Wiring a push to break switch in the UK Electrical Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
