Wiring a switch in a light circuit | on ElectriciansForums
Discuss Wiring a switch in a light circuit in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Kuba
London
Hi everyone, I hope someone here can shed some light on this for me please,
[ElectriciansForums.net] Wiring a switch in a light circuit
I have come across two forms of wiring 2 way switches. I understand the basics behind these, first one with live coming from the light and switched live going back, second using same rule but in com instead of l1 and l2 (strappers in same position).
I guess the question is which one to choose in what circumstances?
Is it based on the location of the switch/light - using least amount of cable when possible or,
Depending on light if it's 3 plate or 2 plate?
I would like to understand it from someone's point of view who's in the trade.
Also, is this correct that in case of 2 plate light wiring you have to bring a t&e to a switch and terminate neutral there?
Finally, last question -
If this was wired in the other form with live going to com from the supply and switched live going from the last com back to the light, you wouldn't have to use a strapper between two coms because that would make it permanent live?
Thanks for help!
Yes it does depend on which uses the least cable a lot of the time. Like you said you can 3 plate the light or the switch, personally I often prefer to do it at the switch as it's easier to terminate there and if you have a light fitting to put up later it's a lot easier with l,n & e there than 3 plate. You might get someone tell you that 3 plating at the switch is not the way to do it but that's tosh in my opinion so long as you have enough room to terminate at the switch, nothing is squashed and it's all neat then it's just as good. In regard to your understanding of switching all I can say is draw them out and you should be able to suss out any arrangement I had a little pocket book when I was an apprentice and if I ever got stuck I would either refer to it or draw it out. Everyone learns in their own way but once you have it straight in your head it's like riding a bike
Upvote 0
Thanks for help!
3 core and earth best way avoiding the possibility of a borrowed neutral
Upvote 0
Reply to Wiring a switch in a light circuit in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
Electrical Courses
