Wiring an Alpha 100 cooker + central heating into S plan system | on ElectriciansForums
Discuss Wiring an Alpha 100 cooker + central heating into S plan system in the Central Heating Systems area at ElectriciansForums.net
J
jimlucas78
Hi all,
Thanks for having a look at my post and many thanks in advance for any help you might offer.
Called to a customers house to sort out an overflow issue - this has resulted in an extensive re-plumbing of a very bad job.... however the wiring is equally as terrible and needs redoing.
Only problem is that this is my first go on a non standard boiler and there's more cables than I'm used to.
The only information I have to go with is this page from a depleted user manual - can't seem to find much online about the Alpha 100:
At the Alpha wiring centre I have cables L,N,E,6,9,10,11.
Happy with the first 3, to junction box terminals 1-3.
6 is not required as controller is mains fed from junction?
9 ???? Is this used for a 3rd channel to control oven only??? - in which case I wouldn't need it as using a 2 channel programmer.
10 Valve switched live - happy with that going into junction box 10.
11 Pump live - again into junction box 10
I'm trying to merge the dated image above into a more standard:
[ElectriciansForums.net] Wiring an Alpha 100 cooker + central heating into S plan system
All in all I'm a bit confused. Any help or up to date wiring diagrams would be much appreciated.
And would I be right in thinking Rayburn bought out Alpha and now offer tech support for this product/
Thanks for your time
James
The cooker has a high limit thermostat that cuts the power to the controls in the event of the high limit thermostat operating/opening that's why the controls are fed from terminal 6. 6 is power to controls via cooker internal high limit, 9 is from 1 channel on programmer for cooker, 10 switched live and 11 pump/pump over run.
Many thanks,
Wish I took photo of what I removed!! Lots of lives and greys badly squeezed into the same terminal!! Makes perfect sense. I expected 1 left over wire but not the 2 I had on paper.
Was that info just sitting there in your head or do you have a link to some diagrams please?
Many thanks,
Sorry mate no diagram.....All in the head :)
Reply to Wiring an Alpha 100 cooker + central heating into S plan system in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
