Wiring an MCB beetwen RCD and Main switch | on ElectriciansForums
Discuss Wiring an MCB beetwen RCD and Main switch in the UK Electrical Forum area at ElectriciansForums.net
Apprentice
Good evening,
I wondered how the MCB between RCD and the Main switch is wired while watching this video. Photo attached.
I assume a busbar link is connected to the main switch and mcb. Do the line conductors and the busbar connected at the same terminal and then go to the RCDSs?
Link to the video:
Cheers
  • [ElectriciansForums.net] Wiring an MCB beetwen RCD and Main switch
Reply to Wiring an MCB beetwen RCD and Main switch in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
