Wiring and Kitchen alterations | on ElectriciansForums
Discuss Wiring and Kitchen alterations in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Hi guys,
Going to a job where they are having a kitchen rip out and new one installed, the upstairs has just been tiled and finished so any works to happen under the boards are a no go, what are people’s thoughts on through crimping for socket movements and chasing down to just below worktop level. Also any other kitchen wiring/alteration tips greatly appreciated.
Cheers folks!
Hi guys,
Cheers folks!
Not a fan of through joints to be honest, I know it's done but personally I don't like it.
Not to sure by what you mean by chasing down to below the worktop level, if you mean moving a socket outlet, then providing everything else is flush then it should be a simple job, can you not spur down, rather than crimping a joint? ughh
I’ve never understood that zone because nobody outside of the electrical trade knows about it, and it puts cables in the perfect place to get hit by nails when coving is fitted.
You NAIL coving?
Bugger me, I've been doing it wrong all these years. Better go rip down all that stuff that's been up for 30+ years and do it with nails.
Damnit damnit damnit... and I wanted the weekend off. :(
You NAIL coving?
I don’t fit coving at all, I’m an electrician.
However the plasters at the building company where I used to work used nails into the wall to hold the coving in place whilst the adhesive was setting.
And one of those guys was over 70 when he retired so I reckon he’d been doing it quite a long time too.
Reply to Wiring and Kitchen alterations in the UK Electrical Forum area at ElectriciansForums.net
P
Leveling uneven kitchen walls for porcelain tiling I will be tiling with 60*30 procelain tiles. They weight about 3.57kg each which is about...
poiupp
P
