This is another real life problem that I fixed this week and it lead onto quite a lengthy chat in the van about the components used, how they work etc. so I figured I'd post it for you guys to have a punt at.
The problem....
If any of you know Cardiff, you'll know all the apartments etc. that have gone up around the bay. Quality buildings
It seems that some of them include air handling units that are running 24/7 providing forced ventilation. These units have, if you will, an overdrive mode that is engaged under certain conditions to greatly increase the air flow rates.
In the apartment in question, overdrive mode is triggered by the bathroom light, the en-suite light and the kitchen light. Unfortunately the 'controller' for this appears to be a pile of poop, with inadequately rated components that are failing, resulting in weird behaviour (the fan stuttering between normal and overdrive) and/or not going into overdrive at all.
The switching is handled by the 'controller' located in a plastic adaptable box by the consumer unit. It has 5 cables coming into it.
3 x 1.5mm single and earth - These provide a switched live supply from the 3 lights that trigger overdrive
1 x 1.5mm twin and earth - This provides the supply for the fan
1 x 1.5mm three core and earth - This provides the connection to the fan (Brown = Permanent Live, Grey = Neutral, Black = Switched live for overdrive mode)
For clarity, the lights are on a different MCB to the fan, but neither have any RCD protection. What the current controller consists of is largely irrelevant, just know that when one of the lights is turned on, it supplies 230v to the overdrive conductor in the 3C+E cable.
Have a punt at drawing up a wiring diagram that achieves the desired results with no unintended consequences
The problem....
