Wiring CM927 relay box into vokera linea 24 | on ElectriciansForums
Discuss Wiring CM927 relay box into vokera linea 24 in the Central Heating Systems area at ElectriciansForums.net
M
markavo
Hi
I have just acquired a new CM927 wireless programmer. I am wanting to wire it into my vokera linea 24 combi boiler but am getting slightly confused. My boiler currently has no external controls and is controlled only by an internal clock which I am aware I have to take out. I have been looking over the wiring diagrams (http://vokera.co.uk/wp-content/uplo...8_installation_and_servicing_instructions.pdf) and can't quite make out which, if any would apply to the CM927. The wiring diagram for external time switches also includes an external stat. But in the case of the CM927, there is no external stat to be wired, just the relay box.
Any guidance would be appreciated
Reply to Wiring CM927 relay box into vokera linea 24 in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
