Wiring Diagram for Drayton Programmer LP111 to Siemans wireless stat | on ElectriciansForums
Discuss Wiring Diagram for Drayton Programmer LP111 to Siemans wireless stat in the Central Heating Systems area at ElectriciansForums.net
B
bigbaddave
Allreet, Does anyone have the above or let me know how it needs wired? Its the usual social housing rubbish thats normally issued.
Terminals on programmer at are the usual - N - L - 1 - 2 - 3 - 4
Terminals on the stat are the usualy L&N - L1, LX, L2
cHEERS
if the boiler requires a 230v switched live link L to 1 on programmer, terminal 3 on programmer to terminal lx on wireless thermostat receiver, terminal L1 on receiver to switched live on boiler. but make sure as some boiler have volt free contacts.
all external controls should normally be protected by the boiler internal fuse, but check the manufactures instructions.
How what is done? What are you wanting to connect them to and how do they need to operate?
Ah sorry, just bog standard heating system. No pumps (excluding combi) etc just combi boiler. All as I want is for the timer (Drayton programmer) to turn the boiler on at the designated time and ovs in accordance to what temp it is in room. If it's too hot then no heating
#6 this is how to connect it up
Reply to Wiring Diagram for Drayton Programmer LP111 to Siemans wireless stat in the Central Heating Systems area at ElectriciansForums.net
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
