Wiring Diagram for Finder 55.34 Relay? | on ElectriciansForums
Discuss Wiring Diagram for Finder 55.34 Relay? in the Electrician Talk | All Countries area at ElectriciansForums.net
W
whazza22
Hi there,
Does anyone have a wiring diagram for a Finder 55.34 Relay?
There are 16 terminals in total.
No Tony I use finder kit myself, as my local wholesaler stocks it so I knew the web address to go to!
However, checking on Google, yes the Finder site does rank top apart from the sponsored links!
From NBP's link
[ElectriciansForums.net] Wiring Diagram for Finder 55.34 Relay?
my tried and tested method involves looking at the wiring diagram printed on the side of the relay, bit small though
Reply to Wiring Diagram for Finder 55.34 Relay? in the Electrician Talk | All Countries area at ElectriciansForums.net
This is precisely my intention with the relay, I'm doing a "bare bones " wiring for the motorcycle. Got rid of quite a bit cables, sensors...
The relay is the one that was recommended with the float switch. The float switch is for use to control the level of a pond, controlling flow of...
