Wiring Diagram for relays | on ElectriciansForums
Discuss Wiring Diagram for relays in the Australia area at ElectriciansForums.net
B
boddingtonsbob
Can anyone please advise how to wire a couple of relays with a standard push button switch, to allow a thermostatic controller, when reaching a certain temperature, to send an input to the relay(s) and thus tripping the switch off. The key thing I want to achieve is that the switch/button switches off when sensing the 240v from the heat controller, and stays off, until manually re-set. cheers
Reply to Wiring Diagram for relays in the Australia area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
