Wiring Diagram Help | on ElectriciansForums
Discuss Wiring Diagram Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
kiwiNCFC
]Hello! I have my 206 exam tomorrow, done all the conduit etc so its just the wiring to do.
Just want to make sure i get everything right, as this is my 2nd attempt due to a mess up on conduit bends.
[ElectriciansForums.net] Wiring Diagram Help
This is the wiring diagram above that a member on here kindly did for me.
Just a few questions:
1) In the ceiling rose's, is it Neutral to Neutral and switched live to switched live? How come the loop bar isnt used?
2) Silly question but just want to make sure : I will obviously be wiring in pvc singles so, will i have to label the switched live with brown sleeving even though its brown already?
Thanks for your help guys!
Reply to Wiring Diagram Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
Brilliant. Thanks Brian much appreciate the advice.
