Wiring diagram with USB/peripheral CONNECTIONS | on ElectriciansForums
Discuss Wiring diagram with USB/peripheral CONNECTIONS in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
damunk
Yorkshire
Let's say in the conventional single phase electrical schematic drawings there is a pc motherboard. All the voltage lines, MCB's etc have been done. How would you now show for instance ; USB from the PC motherboard to a peripheral device such as a printer.
Would it be a straight solid line same as the voltage/earth lines or would it be a dotted line?
Reply to Wiring diagram with USB/peripheral CONNECTIONS in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
