Wiring domestic telephone sockets | on ElectriciansForums
Discuss Wiring domestic telephone sockets in the Domestic Electrician Forum area at ElectriciansForums.net
England
Hi everyone,
Im in the process of renovating my and need to wire up the 3 pair telephone cable to the sockets however im not sure which colour relates to which pin.
Ive uploaded images of the wire and the back of the sockets but if you need more info let me know.
Any help would be gratefully appreciated!
Cheers,
Jonny
just use the blue/white and the white/blue. as long as you connect terminal 2 -2 and 5 -5 that's all you need.make sure that the main socket is a master and all others are slaves. ( you can tell the master as it has a capacitor fitted.
buy a proper IDC tool. the plastic ones that come with sockets are crap.
shopping
shopping
Ok the plastic ones are nowhere near as good as the one you posted but they will to for wiring up one phone connector.
They will, but a decent one is not overly expensive and looks good in your tool kit when a customer asks if you know anyone who can install an additional phone extension point.
You pull out your tool and say "Yes me!" ;)
Reply to Wiring domestic telephone sockets in the Domestic Electrician Forum area at ElectriciansForums.net
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
