Wiring emergency lights | on ElectriciansForums
Discuss Wiring emergency lights in the UK Electrical Forum area at ElectriciansForums.net
London
Hi Guys, how would you wire three gang two way switch for emergency lights so you have 3 feeds coming to the switch aswell as 3, 3 core and earth going to the light aswell as 3, 3 core and earth being strappers to the others 3 gang two way switch new to electrics so help would be appreciated cheers
Lets get this straight... you have 3 rows of lights(?) all 2 wayed from 2 positions. 3 switches at each door or whatever.
You are adding an emergency light?
You need an unswitched live in addition to any switchwire or neutrals to the emergency fitting. Looping through other fittings if nessecery.
You may want to switch this live through a keyswitch... which would mean one of your 3 gangs need to be 4 gang
You could draw out a circuit that you think it needs, and we will see if you’re on the right track
The way it was wired there was 9 cables at the switch 6, 3 core and earths and 3 feeds would it be the 3 brown feeds to the com neutrals in wago and earths in wago plastic fitting. Use the 3 greys going to the light as switch lines and put the blacks in wagos as neutrals. And for the strappers 3 core and earths put the brown in the com. and black in wago and grey in wago. The electrician who wired never told me how he wired it just asking would you know what he did
Don’t use black as N . Sleeve the grey with blue
Use black sleeved brown as a swi line
Although some will disagree and use black sleeved brown as perm live and brown as swi line
What do you do with black and grey for strappers
Brown sleeving in both to distinguish them as live conductors (switch wires)
You’re not really changing what the previous spark did, so how he wired it is irrelevant.
You are adding one core, supplying an emergency fitting with a permanent live which isn’t there at the moment.
No it wasn't, there has never been a 'de neutralising'
I had a thing from the niceic around the time of harmonisation it was a big A4 leaflet about de neutralise black when converting old colours to new. Think several cable manufacturers also produced their own leaflets of de neutral black as well...
It’s even in the brown on site guide I think
Will try to dig it out later
I had a thing from the niceic around the time of harmonisation.
It’s was a big A4 leaflet about de neutralise black when converting old colours to new.
All I have ever seen is advice about old colours and how they correspond to new colours, but not how to oversleeve harmonised colours for different uses.
Reply to Wiring emergency lights in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Or a combined fitting in each row.
nicebutdim
N
