K
kuzmabruk
I am wiring a lighting system using a FINDER 15.81 DIMMER and multiple 9-15W LCD lights and switches at multiple points on a 220v electrical system.
Here is the wiring diagram that comes with the FINDER 15.81 DIMMER
This is how I have wired 2 switches and 2 lights to the FINDER 15.81 DIMMER (note: the brown and blue wires on the left side of the FINDER 15.81 DIMMER are expected to go to the breaker box/fuse panel. I am confused on how to get the ground from the breaker box/fuse panel as I am using a 3-wire.
If someone could let me know whether I have wired this system properly and whether I only need to connect the brown (hot) and blue to my breaker to test my system, it would be much appreciated.
Any other suggestions would be appreciated also.
Sincerely,
Kuzma
Sincerely,
Kuzma
