Wiring for Central Heating Controls | on ElectriciansForums
Discuss Wiring for Central Heating Controls in the Australia area at ElectriciansForums.net
C
chloebear
Hi All,
:eek: I have to first fix some heating control cables, mainly to thermostats, and the heating guy's have all done a magic trick and vanished - so I have 3 programmable thermostats to wire for, my main question is - do the each of the thermostats run seperatly back to the wiring centre box, and next 2.5 or 1.5 cable?
You can probably tell from this that heating controls is not my thing.
Thanks for the reply, it is an oil fired boiler,various zones so I am told, I understand the 1.00mm for the control cables etc would be fine for the valves etc - it's just the size of 3 core/earth for the Thermostats I am unsure of.:confused:
Reply to Wiring for Central Heating Controls in the Australia area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
B
Replace central heating gate valve with 2-port valve My house has a separate central heating loop that heats an annex. The annex loop has 3 x...
Barnjet
B
