Wiring for extractor fan | on ElectriciansForums
Discuss Wiring for extractor fan in the DIY Electrical Advice area at ElectriciansForums.net
Aberdeenshire
currently have extractor fan in utility room for condenser dryer (extracts outside via pipe
Its wired to a 3 pin plug same as condenser dryer that both go into a 2 way extension and into socket in wall so when we click wall socket switch on they both come on together
(that way as well when my sons/wife put on dryer i know both go on)
to cut a long story short can all fans be wired to a 3 pin plug that come on as soon as they are powered without timer/pullcord or pressing any other buttons
Want one that will do this and as silent as possible
Must have missed this thread first time round.
yes. Fans can be wired onto a 3 pin plug if they are a standard model and only require a live and neutral (and earth)
Timer fans need a second live (4 cores)
A 3A fuse must be fitted in the plug though.
I would be wary of a tumble dryer running off an extension lead though. That’s normally a weak point.
Thanks have fire alarm in that cupboard as well (linked to other ones so if it goes off so does ones in other rooms)
Never knew about 3A would have just fitted 13A
Just worried when I switch on at wall it does not come on and i have to press additional button.(reason explained above why i want no additional button
You'd need to post some info about the existing fan (make/model, photo) for comment about why it needs some button pressing.
Reactions: DPG
Reply to Wiring for extractor fan in the DIY Electrical Advice area at ElectriciansForums.net
as mentioned by Westward a link is the way forward, nothing wrong with that and the pull cord will then be the on off switch.
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
