Wiring Help | on ElectriciansForums
Guest viewing is limited
Discuss Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
L
LeccyBumFart
Hi guys, i'm trying to connect a PC Fan to a 12V DC Adapter. When i ordered the fan i was expecting just a red and black wire with it.
The guide i'm reading to connect the two doesn't mention the yellow wire, which from reading up on seems to be a 'tacho'
Does anyone know how i connect these without killing myself haha
By the way i know NOTHING about wiring/electriciany stuff
Any help would be massively helpful!
The reason the cables are both black, is to allow you to choose the rotation of the fan. So connection on way, the fan will extract air, connect the other way the fan will input air.
Eh? I don't think the OP says anything about both cables being black.
Most PC cooling fans nowadays have brushless, electronically commutated, motors. Connecting up reverse polarity will either break them or just not work.
red to red black to black, leave yellow disconnected, put some insulation tape on the end of it.
12v dc from an adapter wont kill you, but is good to power it down before messing up with the wires.
As its a 12v fan he will need the yellow for his 12v + and the black for 0v-
red on a pc power supply is for 5v +
Looked into this further, there are 2 types of brushless pc fan. One BLDC controlled as per Simlec post, and and cannot be reversed. The yellow wire from this type controls the speed by pulse width modulation direct from the pc. The other brushless fan, has no controller hence only power cables, usually red/black, this can be reversed to change direction.
Here's one I made last year for folding@home, due for upgrade.
[ElectriciansForums.net] Wiring Help
Reply to Wiring Help in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
I think you are going to need an electrician because it looks like someone has used the bare earth (has been sleeved black) as a live conductor...
Recommended Sponsor News
Hi everyone,
