Wiring In a Shed, advice needed on SWA route | Page 4 | on ElectriciansForums
Discuss Wiring In a Shed, advice needed on SWA route in the DIY Electrical Advice area at ElectriciansForums.net
Could also use one of these to get internet into shed.
NEVER use those things. They cause serious interference to other users of the RF spectrum, possibly including air traffic control.
Total length is around 20 meters for the cable route.
Anyway, the volt drop would be negligible. Also it’s going to go under the wooden floor and not encapsulated in insulation or plaster.
I know I probably don’t have to run 6mm2, but it’s just if I end up running something a bit heavier than a couple of computers and the lights
If you are allowing for a higher load in the future you need to calculate volt drop based on the higher load.
Reply to Wiring In a Shed, advice needed on SWA route in the DIY Electrical Advice area at ElectriciansForums.net
I hate it when a shed is TTd, why can they not be extended from the tn system? popcorn ready
