hi all, i am about to wire up my shed, its integral to the property, the meter cupboards are next to the shed so i can run a supply through the wall. there will 4 2 gang sockets, bulk head in there and a switched spur for outside light. i'm going to run out from the rcd side of the board using a 32amp mcb. the shed will be wired in singles, trunking and conduit. is this ok to do? was talking to a mate and he was a little unsure as to whether this is ok, i cant see any reason as to why not. is it best to just use the mcb on the rcd side of the board or fit an rcbo instead? this will be used as part of the elecsa assessment.
thanks for any suggetions
