Wiring intermediate switch | on ElectriciansForums
Discuss Wiring intermediate switch in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Hi
looking for a bit of hopefully simple advice.
I am replacing an existing intermediate light switch. As it suggests, it is the central of 3 switches working 2 upstairs lights. First switch by bedroom, second switch this one, third switch downstairs.
The existing switch is as follows:
[ElectriciansForums.net] Wiring intermediate switch
It is difficult to see but L2 is marked in between the top 2 connections. I can't see an L1 anywhere.
This is my new switch:
So my question is how should I wire up the replacement switch?
I have looked on line and seen examples of the 'in' L and N into the top L1 and L2, and equally into L1 and L1.
thanks for advice.
Basically all the conductor are line conductors. The black are not neutrals, so two line conductors from one cable go in L1 &L2 top or bottom. And the other two line conductors go in the other terminations, but....
.... big disclaimer. That’s if the current two way is correctly wired. And it is an intermediate switch. looks like one.
Thank you
so, its cable 1, red to top L1, black to top L2, and cable 2 red to bottom L1 and black to bottom L2. in effect I am matching the current wiring layout.
That is how I read it from some research.
The bit that threw me was that it wasn't clear that this was how the existing switch is wired as, if we assume both top connections are L2, since the L2 marking is plum in the middle of the 2 connections it looks like cable 1 is red to top left L2 and black to top right L2.
Andy
Lots of assumptions. Without testing that’s all you can do, but if the Assumptions are wrong. Bang!
You’re not going to get a bang from an intermediate.
red and black from one t&e in L1 and L2 at the top, red and black from other into L1 L2 at the bottom.
both cpcs together onto metal back box or into connector if plastic.
Don’t put the little screw cover caps on until you’ve made sure it’s working correctly
Reply to Wiring intermediate switch in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
