Wiring - Internal Garage | on ElectriciansForums
Discuss Wiring - Internal Garage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am enquiring about design requirements for a small lighting circuit and a small socket outlet circuit in an internal garage. The house has an RCD protected ring final circuit on the ground floor with no spurs. There is a SO on the wall adjoining the garage on this ring final circuit. Is it compliant to take a suppy from this SO through a 13A fused spur into the garage and use this to supply 2 or 3 socket outlets? Would it also be compliant to take a supply from one of these SO through a 3A fused spur to supply 2 overhead pendant lights?
Reply to Wiring - Internal Garage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
