L
linux44
Hi all,
how would you wire your light switch?
look at the the two pics below
one method i found seem to run a cable from
power to cieling rose and then light switches in order by having switched live and live from bulb joint together like below
http://www.howtowirealightswitch.co...ingle-light-3-way-switch-power-via-light1.jpg
other one is , power to one light switch and then wire through to second switch .. Finally from last switch power to light
http://www.howtowirealightswitch.co...ingle-light-3-way-switch-power-via-switch.jpg
another question is , if you need to be able to switch the light on and off from
more than 2 switches , do you need a 3 way each side and 4 way in middle ?
