Wiring method | on ElectriciansForums
Discuss Wiring method in the UK Electrical Forum area at ElectriciansForums.net
jibjob
Cheltenham
Hi Guys,
Came across this while carrying out an EICR the other day, looks like solid copper singles in some sort of flexible PVC conduit, I've never encountered this before & wondered if anyone could shed any light on what type of wiring method this is, found at the sockets also but in orange. All wiring appears to leave CU in T&E. Property is a ground floor flat built early to mid 80s.
Many thans in adavnce
[ElectriciansForums.net] Wiring method
That there is Gilflex , came across a bit of that in early 90s on a British Legion care home , strange stuff ,,
Used in place of conduit as the sheath is toughened and its just buried so cuts down costs ,,,
Does the sheath come with inner cores or do you have to put them in? I ask mainly because the cores are solid as opposed to being stranded
Conductors tend to snap , you have to be careful with it , also be careful where you drill , the orange stuff is quite a tough sheath and about an inch wide , can be reused , bear in mind the small size cpc on the 2.5 though , also the cpc has green only so requires over sleeving ,,,
The cables you see there are the later 80s , the stuff I came across was 60s ,,,
So if it leaves CU as T&E it must be joined somewhere? I've tried googling it to get some idea as to what it looks like prior to installation but no joy, all sounds a bit M. Mouse to me. The cpc in my photo is in GY, a later install perhaps?
Its not brilliant this stuff , I think Gilflex sort of disown it TBH , I have looked it up as well and its not mentioned by Gilflex , I suppose if you contact them they would tell you more , not sure , I only found the name on a label on the side of it , In your case I should imagine theres a joint box somewhere , if it all tests out O/K I wouldn't get involved with it , because where this is used is mainly in concrete bunkers and would be difficult to rewire to say the least , unless you had to of course ,,,,
Thanks guys for all your help, wiring tested fine where this appears to of been used, eventually, no earth at last light, found break at a light fitting up stream & your right Ray, there ain't no give in cables, the cpc looked as thought it had popped out due to being a bit on the short side.
Hi Guys,
Reminds me of this for some reason
http://submit.boingboing.net/files/2012/03/280X.gif
Reply to Wiring method in the UK Electrical Forum area at ElectriciansForums.net
