Wiring nest to boiler | on ElectriciansForums
Discuss Wiring nest to boiler in the Central Heating Systems area at ElectriciansForums.net
R
Reece Whelan
Hi guys just want some confirmation before I do the job, to wire a nest into the boiler is it a case of taking out the link in the boiler connections taking a cable from there and also live and neutral for supply?
Reply to Wiring nest to boiler in the Central Heating Systems area at ElectriciansForums.net
As a "temporary" measure I went down a slightly different route. Nothing off the shelf appealed. In particular I wanted something with a good WAF...
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
