G
gaz26
Hi all. Someones asked me if i can wire a shower in there house. On inspection of there fuse board i saw it was an old re-wireable one and also does not have any spare ways on it. I dont want to change the fuse board for a bigger one because that will mean i'll have to do a periodic and most probably have to re-wire the lot.I'm trying to just add to the circuit if i can. Am i right in thinking that the best way would be to put the supply to the old fuse board in henley blocks,then tail off to a 2 way enclosure where i can put in a rcd, then connect the 10mm from the shower to that?
Thanks in advance
Thanks in advance
