WIRING programmer issue | on ElectriciansForums
Discuss WIRING programmer issue in the UK Electrical Forum area at ElectriciansForums.net
J
joehat
As per pics, I can see the conversion chart and how it's done, but theirs no number 6 connection in the old programmer?
Is this needed, ? As it says to terminate it 2?
I haven't done many programmers, usually their simple but this ones got me.
Pics of new WIREING and current programmer needing replacing.
Thanks for any replays and help?
[ElectriciansForums.net] WIRING programmer issue
On old programmer 1 is HW ON, 3 HW off and 4 is CH on. 2 and 5 are commons which aren't needed on new programmer and terminal 6 is CH off which you obviously don't need as would be connected to old programmer if it was.
On old programmer 1 is HW off, 3 HW on and 4 is CH on. 2 and 5 are commons which aren't needed on new programmer and terminal 6 is CH off which you obviously don't need as would be connected to old programmer if it was.
Lee I might be a bit dozy tonight but 3 and 4 are a NC and NO respectively - so only 1 of those is an 'on' .
Reply to WIRING programmer issue in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
