Wiring sensors | on ElectriciansForums
Discuss Wiring sensors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
nabba
Hi, I'm wiring lights about 20 via trunking in singles to loop in boxes , because the room is large I will need to position at least 2 or 3 sensors so either one will bring lights on ... Any advice on the wiring them pls ? I realise first off , live neutral earth to supply the sensor what do I take to the other one to incorporate it then obviously switch wire to lights its just the sensors im itchin my head at ... been that long time since did this sure it's simple just need direction
Thanks ...
Hi , thanks for getting back. Yes pir's this is the thing parellel ?? so live neutral earth from the board into first pir then would it be live neutral earth to the next one and a switch wire so that either pir switches they will all come on is this right ...? Parellel always confuses me in lighting
Thanks again .
Yes, line, neutral, earth and a switch live need to be taken between each pir.
What type of light fittings are you switching, make sure the PIRs can switch the required load.
Thanks again, I think at the moment it's going to be 600x600 square fluorescents placed into a new office refurb grid ceiling ,... Not sure what the wattage is on each one yet as drawings not arrived ...
you do need to know the load.............. to condier zs value and vd... you could break the room up say first 10m the lights come on walk a little further and the next set come on
Reply to Wiring sensors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
very few capacitive sensors are suitable for direct insertion into a safety circuit. the only ones that i have ever come across have there own...
