sibeer
First post here so please be gentle. Looking for a helping hand on wiring lighting for a three storey home as it is baffling me a bit. What I want to achieve is the following:
GF: Four gang switch operating the outside light, porch light, ground floor hall light and first floor hall light.
FF: Three gang switch operating the ground floor hall light, the first floor hall light and the second floor hall light
SF: Two gang switch operating the first floor hall light and the second floor hall light.
Bit of advice would be much appreciated
As Robson689 says... straight forward. Above switches easily available.....Split over 2/3 circuits, just from a safety point of view if one circuit has a fault, some lighting left working.
do you want help with actual how to wire and connect? or something else? sounds very basic TBH, sorry to sound sarcastic but really is a basic job.
At a guess, if he isnt using grids or clicks, as robbo suggests then he will struggle on standard switches. ie the intermediate with a 2 way, they dont do them. but i cant see an intermediate in his set up.
edit lmao im talking in riddles today
actually mem can be taken apart and intermediates installed, buy a 3 gang 2 way switch for example and a 1 gang intermediate and you can take the switch out and alter it, there is a brass screw holding the switch in, mem will do the job
Yrs ago with Ashley 2 gang 3 gang or 4 gang standard light switches you could remove a 2 way switch and replace with an intermediate switch.......bit like a grid system. Not so sure you can still do that now. Bit out of touch!
Yes i know we can butcher a switch to suit, but it wasnt designed that way, and neither was my hammer rashed fat arthritic fingers that nimble now lol.
CBA mentioning/explaining another single backbox on first or 2nd flr
You are looking at the classical multiway stair switching arrangement.
Don't forget to label your cables at the switches because what looks simple on paper becomes a headache in practice.
I had this as a prospective dilemma on one job. the client wanted touch button control on all lighting circuits. I thought fair enough but does she really want these? So I worked out how the cabling could run to satisfy both arrangements. and sure enough she had changed her mind, typical, and wanted standard light switching.
So as others have stated use a grid switch assembly, looks reasonably neat without confusion.
No need to butcher anything bud, I am against that type of practice, the MEM switches are almost grid like and do just come out with unscrewing a brass screw and then you can add a different switch, how dare you suggest I would recommend butchering anything, fisty cuffs at dawn at junction 11a of the M5 please
I was trying to use another word but the profanity filter was kicking in lol. Aye and you want me to do a 5 day camel ride down the country just to bleed all over you.
Sorry for the delayed response, thought I had subscribed to the thread and it had not had any responses yet. Judging by the responses I clearly have the right forum. First off I am not an electrician. Hopefully that won't get me shunned right away. I am running wires and buying parts for my electrician to do all the final connections and testing.
As MDJ says, I am looking for basic level support. I have the flexibility to work to whatever wiring is suggested as the house is pretty much a shell at the moment. The switches are really what drew me here as I want all my switches to match throughout (even though they will probably be just white plastic. The Grid system is what my electrician mentioned, but he they talked about custom switches made up of blocks that would not match in. This was pretty much my reason to come on here and find out more.
Click light switches are like that now too and just look standard when on the wall
If your electrician is doing the connections then he should be telling you what to run and where and then inspecting your work at each stage as you go before anything is covered up! Ask him to look at click or mem as Mdj suggested
Just write down what you need and then buy it. Grid switches would be the usual method, but as said you can create your own custom switches using MEM or apparently Click.
He is doing that, I just thought if I found a solution other than his grid switches I should have the full information. Looking on the Scolmore (Click) website and their modular definity range looks like it could be ideal, but also expensive. Will come up with a list and price it up. Thanks for the suggestions.
Switches are the bit you see and the easy bit. Get your sparky to specify EXACTLY what he needs as you'll struggle in B&Q
I have no intention of going to B&Q as I want to buy the right products at the right price. I have an account with my local wholesaler (Eyre and Ellinson in Liverpool are by my work).
Found that site as soon as I searched Click. Seem a good place to point my Spark too once I have a basket together.
Next question then. My spark will let me know how many twin and earth and three core and earth to run to and from each location. What switch modules do I use from that site for the switches that do the same function on two and three floors?
You'll be better off asking him/her what they want and where
Oh Sibeer. Your spark is advising you yet you come on asking how to carry this work out. If you're doing DIY electrics at least have the decency to be open and honest about it, we must get at least 3 of these "My electrician says" threads a month and we can see through them mate.
Are you sure, does he exist? You have an account with a wholesaler?
As I stated before, sit down with your spark and agree the shopping list.
If I was advising a client who wanted to save a few quid on how to do a job and found out he was going to an internet forum to second guess me I'd be mightily annoyed and the price would probably go up.
I am annoyed, bloomin furious in fact ! after I painstakingly drew out this switching arrangement for him on that smoke packet and everything.
Well thanks for the accusation of lying Trev, sounds like you need to invest in a fresh pair of specs as you are barking up the wrong tree rather than seeing right through anything.
My spark is running on a day rate, not a job rate. As such (to my mind) it makes sense to research and solve things myself rather than add to his time and bill.
To give my full life story (given the accusations): I am changing two flats into a house as a conversion under building regs. Buying the other flat has taken me to the extremes of my finances so I am trying to control and understand costs wherever possible, which includes micromanaging the project. I run a factory for my day job with a large number of woodworking machines, hence why I have an account at the local wholesler to my work for all the odd parts we need.
Given I want to get this signed off by Building Control at the end I would be pretty optimistic to DIY the electrics.
Oh and Andy, if you could scan the smoke packet in that would be ace
Joking aside....
Like has been said, you need to ask your spark this info. There is not just the one way to do this, and he needs to be telling you the way he wants it doing. Researching it yourself and installing might save you money. But it also might cost you more if you balls it up.
Joking aside....
Joking aside, I don't really want the smoke packet diagram, I won't be doing anything without running it past my spark first. My only outstanding question was what modules I needed to go with the Click faceplates. If there are different ways then fair enough, in my limited knowledge I had it down as being as simple as ones suitable for switching from one location only, ones for two locations and ones for three locations.
When I'm working on a day rate I don't charge for out of hours research, I put it down to doing a good job and keeping the client happy.
Isn't your spark self certifying?
Research what? if your spark needs your help with this then I would recommend you ditch him and get a real one in
Aye ........... Jimmy Riddles. ;)
GF: Four gang switch operating the outside light(1W), porch light(1W), ground floor hall light (2W) and first floor hall light (2W).
FF: Three gang switch operating the ground floor hall light (2W) , the first floor hall light (INT) and the second floor hall light (2W)
SF: Two gang switch operating the first floor hall light (2W) and the second floor hall light (2W).
Likely switch types above, but do check with your spark if this is what he is going to wire.
Wiring the lights for a Three Storey Home
sibeer,
Richard Burns,
