What does the NC terminal on the HW side do on a time clock? The wire from the NC terminal is connected to the grey of the 3 port valve. A 3core flex goes to the cylinder stat. The brown is connected to the NO hot water terminal on the timeclock. The blue wire from the cylinder stat is connected to the orange of the valve. The yellow/green wire from the cylinder stat is connected to the NC terminal of the Timeclock and also the grey of the valve. I can't remember what each wire on the valve does.
