R
Rallyace
Hi,
I am new to the forum. I have a a detached garage which is about 2 meters away from the house. It currently has a single double socket with a single 2.5 cable running back to the CU in the House. Due to the fact I am running several arcade machine in the garage and really need 6 double sockets, I want to run a new ring in the garage. I have 2 new 2.5 cables run under the floor in the house from the CU ready to be connected to a 32a RCD.
A couple of questions
1.Do I need to switch to Amoured cable to run the 2m underground between the House and the garage or can I use a suitable conduit? If so would Adaptaflex Liquid Resistant Covered Steel Conduit be suitable?
2. Do I need any additional protection or is the 32a RCD at the consumer unit in the house ok? The garage is only a couple of meters from the house.
