Wiring type. | on ElectriciansForums
Discuss Wiring type. in the Electrician Talk | All Countries area at ElectriciansForums.net
M
Mr Mike
Hi guys,
May I ask for your thoughts on wiring a new build.
The options being talked about are A) trunking and single cables or B) cable tray and twin and earth.
Personnally I would opt for the trunking and singles but cable tray and twin seems to be getting some head way. I understand there will be cost saving with twin.
The application is power, lighting in a new build.
twin on tray looks like a bag of spanners. Ive installed that method before, on shop fits, but i didnt like it. It all depends on if it can be seen or not for me. If it cant be seen, then i would maybe go for twin on basket, but if itcan be seen, then it would be trunking and singles,. If budget wasnt the primary concern, the it would be trunking and singles anytime. the last method is also a good way of ensuring that there is no risk from rodents, and also makes the sytem easily rewireable.
To be honest Mike I'm old school and prefer Trunking/conduit installations for commercial/industrial as to my mind these type of installations tend to be more fluid when it comes to re-designing areas, introducing new equipment, changing offices around into stores etc etc.
With T+E and even SWA/Hi-Tuff are used you are literally if the area is changed or altered then all you can do is rip out and start again, whereas you can always utilize a trunking.
Yes tray/basket with T+E is easier and perhaps in the short term cheaper and unless there is an environmental reason then no reason not to use it. Just for me it is not using the best options.
Like John and Malcolm I’d go for conduit and trunking. Aesthetics apart once the trunking is in you have a backbone that can be added to as required.
T&E and basket with switch drops in plastic tube.
I don't see that singles in trunking is any more rewireable than t&e, and basket can be added to just as easily, if not more so.
Looks like it's all down to what the modern day electrician is capable of installing again!! So it'll probably be the cable tray and T&E, as most of these new electricians run away from anything that needs a bit of skill in the designing, and installing of anything half decent. Unfortunately that includes metal trunking, metal conduit and the like etc!! Any excuse and those containment methods are dumped, in favour of the crap that they call/consider a commercial/industrial installation. But it's just pants, and dam well looks pants too!!
What have you priced for???
Or is it a given i.e come and wire this building for me???
If it's a given, galv it, job done.:troll:
Why would you spend 3 times as long and 3 times as much on materials if they're only going to rewire it in a few years anyway?
If it's a new build to be rented out it'll probably even be rewired within a matter of months when the tenant moves in, to their specification.
It's far easier, quicker, cheaper and more flexible to be able to clip or bolt accessories onto the side of a basket than have to lift all the cables out and drill into the side, then grommet it off when the occupier decides they don't want it like that anymore.
I agree that when done well galv conduit & trunking looks the business, but there's no point going out of your way to install it unnecessarily just for folly; nowadays most clients want an installation which works safely for as little expenditure as possible
I'd much rather use a new fangled hammer drill, plastic plugs and an impact driver than go out of my way doing things the old fashioned way with one of those chisel thingies, fibre plugs and a manual driver.
Thanks for your thoughts guys.
Lenny not at the price stage - just discussing containment etc.
I take on board all thoughts. My feeling is to push for trunking, galv conduit and singles, I feel comfortable in this, but unfortunately it is the clients money and he will have the fimal say. I want to give him as many pro's and conns as poss from the start, so to avoid the "I wish" after the event.
It is fantastic that this site exists, with some many good, positive and constructive comments being given - for that I thank you.
I agree that when done well galv conduit & trunking looks the business, but there's no point going out of your way to install it unnecessarily just for folly; nowadays most clients want an installation which works safely for as little expenditure as possible .
If you read post # 6 of this thread you have your answer...
Oh dear!! You see i wouldn't even give that installation a second thought, let alone a first thought!! ...lol!!
Reply to Wiring type. in the Electrician Talk | All Countries area at ElectriciansForums.net
Cant be C and B as different CCC. Table 4D5 might help!
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
