wiring under floor boards | on ElectriciansForums
Discuss wiring under floor boards in the UK Electrical Forum area at ElectriciansForums.net
P
pb8
Hi all I've been asked to wire a friends house but it's got a space under ground floor floor boards. Can't remember ever doing one before. Do I need to put cables in tube or are they ok just resting? Can't see anything specific in big book.
Originals just lying there so I'm assuming I'm ok to do same.
Thanks all
Paul
All cables should be supported, not lay on the dirt under the house.
mind you ...you see it enough times...cables just layin underfloors that is....and not just new install either.....plenty of VIR install done that way...
now...cables should always be supported...theres a very good reason for this n all..
a fault reaches full potential on the first quarter cycle.....and inclipped/insupported cables subjected to this can rupture as a result....
Never new that, are you sure?
Many re-wires are also done that way, and I am also guilty of it.
it is not always possible to clip the cable along the full length of the joists, although I always try to wire across joists so they are supported by the holes.
However, I would never leave unsupported cables lying on the ground underneath the house.
It is possible if you have to crawl on your belly under there like I did a few months ago.....was aching for a few days after mind, using muscles I never have before....end result sort of worth it that I know it was done properly clipped the whole way no sky job....I stunk afterwards from the damp down there aswell.
Tbf I did a bit of both, but there were pipes making the gap even tighter in places so had to use my toes whilst on front to move anywhere, it was a nightmare, I would then get in position then shuffle on my back to clip, whilst looking out for our eight legged friends which luckily I didn't see any thank god lol
Nothing wrong with unsupported cable runs in ceiling voids etc. as long as the surface is reasonably smooth and not likely to damage the cable. In domestic work it's often the only option!
could be acids or stuff in the soil that attacks the cables. cables should be clipped to the joists, even if you can only get a few in. a skinny apprentice comes in handy here.
Did a rewire recently where previous sparks had jb's laid on ground..
Only became a rewire when I changed the cu to rcbo's
Plenty of void space underneath to climb down and clip (about 4 ft ) end result was happy Rcbo.
Reply to wiring under floor boards in the UK Electrical Forum area at ElectriciansForums.net
Live wires under floorboards? any years ago, when my daughter was just a crawling stage, we were having a new carpet fitted in an upstairs room...
Floor tiling 600x600 48m2 Hello, this is my first post here, but I have been doing some reading. I am going to be tiling the whole ground floor...
Spacebug
