Hi, recently got a garden room and completely wired it up but running into a snag. Is there any way I can use dimmable led batons that have Dali output with just a dimmer switch as I’m having problems getting it to work.
I know usual you have to have a permanent feed at each light and switch wire. Is there no possible way I can just dim it up and down with dimmer switch with just switch wire at each light.
Try using the switch
You can try the Touchdim function, remove the dimmer switch and use a retractive switch, like a bell switch to control the on/off dim up dim down functions built into the driver. There is a little diagram on the driver to show you how to wire it up
Belfast
United Kingdom
Electrical Engineer (Qualified)
Wiring up Garden room (Need help on Dali light)
Domestic Electrician Forum
ReganE,
plugsandsparks,
