Wisedim with LEDs | on ElectriciansForums
Discuss Wisedim with LEDs in the UK Electrical Forum area at ElectriciansForums.net
Hey Guys, I'm using a Wisedim from Wise Controls with dimmable LED lamps. We have an issue with the number of LED lamps not quite meeting the minimum load of the dimmer causing flickering. If we put 1 halogen lamp in each dimmable zone they dim absolutely fine. Problem is we can't leave an halogen lamp in the circuit as the light output won't match. I've heard of load resistors to increase the load. Anyone know anything about this? Thanks
Reply to Wisedim with LEDs in the UK Electrical Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
