Hi,
I have been asked advice on installing a smoke detector inside a small wooden shed at the bottom of a garden, which is currently used for spray tanning. I have said that a smoke detector will be of no use as the mist from the machine will constantly sound the alarm. I thought I could fit an Aico heat detector, however am unsure whether the temperature inside the shed could ever raise to over 58 degrees and therefore cause a false alarm? It could be hours before the resident returns home so would be a massive annoyance to the neighbours.
Any thoughts on this?
Regards
Regards
