Working at height? | Page 2 | on ElectriciansForums
Discuss Working at height? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have a tripping RCD in a church. The faulty circuit supplies 5 x spotlights which are on the inside walls of the church. They are as high as trying to reach above a first story window in a house so perhaps 5m above ground. I will eliminate all other possible faulty parts (switches etc) before invesigating the lights but it's highly likely it will be the lights which look subject to damp and also perhaps birds nests.
I can foresee the church pews making it difficult to get a ladder in between them, although it might fit as it does not have a supporting bar at the bottom.
On rare occasions I get my big ladder out if I have to work at height (see pic below of my ladder) but it will only be for a short, simple jobs and I feel uncomfortable doing this in the church by myself.
[ElectriciansForums.net] Working at height?
What would others do in this situation?
Would you have someone with you? How would that actually help?
Would you put up internal scaffolding? That would be a much larger cost.
Would you somehow secure the ladder?
Thanks all. :)
It will be good to see what one of the 'towers' look like, although I think I am erring towards scaffolding due to the limited access. I expect they'd be able to get scaffolding up between the pews.
I do a bit of work at our local church. Had the same problem with spotlights that I could luckily teach from the balcony.
The biggest problem was “old joe” the caretaker of the past would change the lamps, and put the faulty ones back in the store room beside the new ones.
7 boxes of lamps and only 1 good one found.
ive suggested the get LED ones into stock.
Another balcony had lights that were tripping their mcb. Due to the balcony not being used for safety reasons, I disconnected the part of the circuit going up there.
a big problem with churches I find is the location of the db is in the most awkward corner they can find.... and of course, you can’t swear in a church.
Reply to Working at height? in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
