Working at height? | Page 3 | on ElectriciansForums
Discuss Working at height? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have a tripping RCD in a church. The faulty circuit supplies 5 x spotlights which are on the inside walls of the church. They are as high as trying to reach above a first story window in a house so perhaps 5m above ground. I will eliminate all other possible faulty parts (switches etc) before invesigating the lights but it's highly likely it will be the lights which look subject to damp and also perhaps birds nests.
I can foresee the church pews making it difficult to get a ladder in between them, although it might fit as it does not have a supporting bar at the bottom.
On rare occasions I get my big ladder out if I have to work at height (see pic below of my ladder) but it will only be for a short, simple jobs and I feel uncomfortable doing this in the church by myself.
[ElectriciansForums.net] Working at height?
What would others do in this situation?
Would you have someone with you? How would that actually help?
Would you put up internal scaffolding? That would be a much larger cost.
Would you somehow secure the ladder?
Thanks all. :)
Do they tell us not to use ladders now?
Now, @davesparks we all know what I meant. and as mentioned on a previous post..... 3 points of contact on the ladder..... only to be used for access and not working from.
Its all down to the heights involved and common sense.
Yes, 3 points of contact, but as taught on the last working at height I did your knees can be points of contact.
They shouldn't be used for long periods of working, but for short duration tasks such as changing lamps and fault finding I see no reason not to work from a ladder of it's the only access equipment which sensibly fits the task.
The suggestions in this thread about having scaffold built or using powered access inside a church seem ridiculous to my mind.
[automerge]1583956989[/automerge]
Liking the 3rd leg (she said) for stability. Not sure about being enclosed in the cage though - bit restrictive?
That's not much different to the basket on a tallescope.
I use ladders quite regularly. As long as they're footed and common sense is used, no problem.
I did use scaffold in a church last year for changing some lamps to led corns. They were central (no walls) and we just shifted the pews to suit.
In one old church I installed a winch in the attic for a multi lamp fitting.
EDIT. The pews were old, fixed and couldn't be seperated.
Had to Google that Dave. Useful bit of kit, bet they're not cheap.
That's OK if the pews aren't fixed
[automerge]1583957680[/automerge]
A tallescope? You'll find one in pretty much every theatre, they're pretty much a standard piece of access equipment.
They're a bit unnerving until you get used to them, they can be a bit wobbly at full extension!
in a church, surely god will protect you?
on a more serious note, never attempt to do a job without the right equipment.
chance it with a ladder, you can get away with it for years but one day it WILL get you.
the church will not provide for you whilst you lie crippled.
Reply to Working at height? in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
