working on site / pulling cables | on ElectriciansForums
Discuss working on site / pulling cables in the UK Electrical Forum area at ElectriciansForums.net
J
jmusson1989
Im doing level 2 electrical engineering NVQ at college and trying to get experience on site to get me through level 3 and to help for the future. Just had a call, might be going on site this Monday to pull SWA cables on an industrial site.
What's it like? What should I expect?
What colour CSCS/safety PP should I need in my circumstances?
Get your thick skin out, & get ready for some great jokes, don't mention you're trying for a baby otherwise every bloke on site will offer to pop home (to yours) to help you out, and if someone asks if you if you have any naked pictures of your wife/girlfriend on your phone, expect (after saying "no") the reply "do you want some"!
Oh "what comes after S in the alphabets a common one, if you make a cup for a plasterer chances are he'll drink it with the bag left in
all depends on the site i suppose. i would imagine hi vis, boots, hard hat and gloves would be a must for me whether they're required or not. be ready for a fair bit of graft!
lol yeah, the bloke said there'll be plenty of banter, but that's to be expected, I'll be so happy to be getting experience that I won't let it bother me. Really, I meant what's the work experience like, pulling SWA cables and such, I've done a small SWA socket circuit at college but nothing on an industrial scale :p
depends on size,put it this way i,ve just finished pulling in some 150mm 4 cores and when i got home the first thing i wanted was my bed, absolutely knackered,thank god there,s only 1000 mtrs of 2.5 left!
wow, lol. how's the cables fastened down then and secured? Do you have to do that after pulling it all? Also when on site, how do you wire SWA, at college it's easy to use just some mole grips or something, but I imagine with thicker cables, it's have to be a really big pair of mole grips to fasten that and a lot of effort, lol, so how's that done?
Not sure if you'll be terminating the SWA that will be left for another team, but you maybe lucky. Normally the pulling "dogs" do the grunt and it's left to us clever chaps to terminate :laugh3:
What is the industry coming to ..................terminating SWa with "molegrips" disgraceful, where was your pair of "footprints"?
Well if it is FB SWA then you'll be swinging on a pair of 36" or 48" Stilsons
lucky you, I was the same in the good old days now I have to get hands on,as there is only me on the sparking at the grainstore where I work,still the labourers have a new respect for me after giving me a lift with that job,one said he thought sparks had it easy now he realises its not all plain sailing.
Hi its all a question of scale, same procedure with any armoured,its just bigger tools and a damn site harder,you,ll see when you get out there.
Depends on size of cable really, but I would seriously invest in a decent pair of safety gloves in case its a bit of a beast - just watch them fingers
[ElectriciansForums.net] working on site / pulling cables
Take a couple of rolls of white insulation tape and a couple of sharpies (Permanent makers) you can get them in tescos.
Keep an eye out for pieces of cardboard to save chathing the cables, if there is a twist gather it into a hoop and walk it out. Always roll the cable out, dont let it uncoil off the side causing twists.
If there is a large diameter cable ask if you are running a seperate CPC as well.
If you are pulling through ducts ask if they want another draw wire run in as well for the next future cable.
Make sure you have some cable ties, most just hold them in the corners untill they are all in ready to be dressed.
If you are in a tight area where there is ducting, half finished grid ceilings etc, MOVE YOUR HEAD SLOWLY, there are many sharp edges and uncut suspension wire that could have your eye out. Same goes for basket, look out for burrs.
Reply to working on site / pulling cables in the UK Electrical Forum area at ElectriciansForums.net
Thanks for this reply, this has helped!! I felt quite deflated and let down by this experience (1 bad thing wont end my hopes of being a full time...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
