working out mft | on ElectriciansForums
Discuss working out mft in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
lfcsparkycus
got myself a fluke 1653, been figuring out the functions and how it works etc, but am unsure on the pefc/pscc because its a 3 lead test, do i connect all 3 at the same time, when i done 2330 we used kewtech stuff which was 2 lead test, i want to be 100% sure before i try it out
Have you checked youtube out? Often videos on there showing functions of various testers.
good point, ive got the instruction disc but it doesnt work on my computer, got to get a new one(disc), trouble is i cant wait because my new toy has arrived and i want to play with it now
on my fluke 1653 when you turn the dial to test, it shows the leads to use on the display screen.
You can down load manual from fluke webb site
short circuit current says use l & n, i understand that, but pefc says use all 3 so what im trying to say is do i connect all 3, green to met, neutral to neutral and live to live
Reply to working out mft in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
