would like advice on main board with rcd being used as main sw | on ElectriciansForums
Discuss would like advice on main board with rcd being used as main sw in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bobby101
hi all have been doing some pir,s recently an im a little rusty on a few things got lots more to do an experience is key got a query re a small domestic house with a main board being fitted with rcd as a main sw, protecting approx 4 ccts, lts/ skts/cooker/ shower... on the lts cct also has the alarm and smokie with no seperate fused connection unit
would i recommend the following,
1. no additional protection
2. incorrect main sw
3. circuits not seperated
any help with this and any help with the inspection checklist would be great
if the board was fitted prior to 17th, then the above points are IMO just a code 4. with the xception of the alarm. it should have it's own FCU or it,s own MCB. the smokes are fine if wired into a frequently used lighting circuit.
1. no additional protection If the main switch is an RCD then ALL circuits have additional protection (assuming it's 30mA).
2. incorrect main sw Can you back up your thoughts on why you think it is incorrect though??? for me it would warrant a code 4 in this instance.
3. circuits not seperated Well they are, as you have 4 circuits and it is quite common for smoke alarms to be connected to lighting circuits.
The other alarm to which you refer is that a security alarm with no means of isolation other than the lighting MCB???
What area's are you not understanding about the inspection schedule???
Reply to would like advice on main board with rcd being used as main sw in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
